Hi.
Cheers.
Hi @SatB_81
I have been known to simply buy a "plank" to fit the TV Stand and with a bit of paint or varnish blend it in nicely.
Can you turn the legs 180 degrees, or swap them one for the other, so they splay inwards?
Cheers. I will have a look and see if that works.
I don't think they can be adjusted. Sony created an article for TVs that can have there stand adjusted here. So you can try these suggestions see if it works for you.
Cheers
