KD55A8. Adjustable feet height for soundbar.
Just bought this.  Can the feet be adjusted for height as suggested in the Setup Guide?  There appear to be 2 options set at 25mm and 75mm.  My TV was set up by the supplier.  It was only later that I read that the feet were adjustable.
There is a footnote saying that this option is not available in every country and on every model, but without being more explanatory.  I am in the UK.   Thanks for any comments.
3 REPLIES 3
Win_88
Specialist
Yes it can be. Basically, if you have all the parts illustrated in the Start up Guide, you're good to go.
ClevedonCodger
New
Just set up my XR-55A80J  in time for the footie and it made all the difference - England won 4-0!
Seriously these feet are a nightmare - the start up instructions are graphics only and as a result we now have the feet set on on the lowest height and at the far edge of the screen, but really need then closer together as shown in the instructions. However I can't seem to extract the feet from the base of the TV.
Is there a release button or a technique to do this?
HannahEd01
 Hey, IDK if you have the following manual, but it seems that there are screws that you need to unscrew:
https://www.sony.com/electronics/support/res/manuals/5026/23bd38fb4dbb1b16378589fc067d8fc4/50263461M...
