When I try to set up satellite tuner it is greyed out on the menu system. I have doiuble checked satellite cable works as it works via the set top box. It is a Fressat dish with twin LNB. two cable inputs available, both checked out OK. Why can I not get the digitalk tunimg system to see the satellite connection?
Welcome to the Community. I'm looking into this for you now. Will come back with a suggestion asap.
Thanks,
Drew
On My TV ( different model ) if you have Youview enabled it Disables Freesat and Freeview...
