Hi
Just had my Bravia 49XE8077 fixed after a firmware update that went wrong and the guy that fixed it has put on a software from a different model. The software looks the same with all the same functions, it just when I look what the model of TV is in settings, it comes up with a different model. I'm assuming this is ok, just checking?
If it's working fine then i would leave it. Another option would be performing a factory reset.
Thanks, Drew
