Has anyone managed to overcome the problem of single audio output on this model? I am deaf but my partner is not so I should wear headphones but this is not possible.
Any advice much appreciated.
Solved! Go to Solution.
I found out this article which clearly indicates that the only option is to use optical connection.
@royabrown2 yes I meant a bluetooth or radio repeater not an headphone connected directly via optical (that even if exists should be rather uneasy since optical cable are quite rigid)
You should opt for a headphone set that can be connected via the optical connector
That’s a bit elliptical, and I don’t know any headphones that do that directly.
But you can get an optical to Bluetooth converter, e.g. :-
and then use any Bluetooth headphones you already have, or choose to buy.
