Xperia 10 iii no network with Vodafone card
mati27
New
Hello,
when putting in my Vodafone sim card the mobile services start crashing instandly, The netzwork icon in the upper right is disappearing and shwoing again, sim card 1 in the setting gets grayed out and show again constantly.
After a time the sim card get's fully diabled. The card is working fine in anothe device and in the xeperia 10 e.g. a Medion sim card is also working fine. So it is an error only appearing in this combination xperia 10 with my Vodafone card.
Tried the follwing thinkgs wihtou success:
Restart
reset mobile settings
Flight mode on/off
installed alle updates
removed the Vodafone app.
Best regards
2 REPLIES 2
Piscie
Hey @mati27, have you tested different SIM card on your Xperia 10 III to check how it would work? You can also try the safe mode, your phone will restart with the pre-installed apps only so that you can confirm if the issue is caused by one of your downloaded apps or not.
mati27
New
yes this is also happening with another Vodfone card. Also in safe mode
Best regards
