screen recording - no internal audio
SOLVED
backslashhh
When using the screen recording, the internal sound (not mic) is not recorded. On the Z3C it records also the game/app generated sounds. Known issue, or can I somehow influence the mixer settings?
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Johan
Master
@backslashhh wrote:
No, I don't. Microphone recording works. Game sound not.
It sounds like the sounds effects of the game application you're trying to record may be protected (copyright). That's probably why you don't get any internal sound effects recorded.
8 REPLIES 8
Uliwooly
@backslashhh
Do you have a voice recording app or ok google on ?
backslashhh
Uliwooly
@backslashhh
Perhaps @Johan could elaborate on this.
Johan
Master
backslashhh
Simple experiment. Turned on sound on touch. Recorded simple homescreen interaction. No sound recorded.
backslashhh
Thanks
Ok, I was wrong. The Z3C has the mic turned on by default. So it seems to record only via the mic. I guess recording directly from the soundcard is disabled because of the mentioned copyright. Consider this "solved". Thanks
hoanganhpham
Soft ware : fixed you can't on or off internal audio
Hard ware : you can on your head phone with "freezed" mic
AndroidBruh
This is an excuss not a fix
Answer the question!!!!
#((_@#-_@
