Moro mulla olis tollanen kone: VGN-FZ31Z ja nyt tein niin kuin ohjeissa sanotaan tuon palautus levykkeen. Nyt kun koitin asentaa niin tokan levyn kohdalla tulee Error: 305:69 mikä mahtaa olla vikana? kiitos
Hello i have vaio: VGN-FZ31Z and i try make the restore disk and and it was ok. When i try to install it in cd2 installition stops and this is only what it does -------> Error: 305:69?? What is the problem??
Hi while i have the same sort of problem i have trolled the net for solution to mine i did find info on tis i think it is a read access error which means the disc cannot be read by your optical drive to confirm you could try copying the dvd using software like nero and try copy dvd to image or test te dvd using the tools within nero.
Or it could just be a bit dirty give it a clean with a lint free cloth and try again.
hope that helps some.
rev
