PIONEER DVR-K12D (aka PCGA-DDWGT1)
cmsd
hi community,
recently I'm looking for helping hands in regard to following problem:
GRT816S with PIONEER DVR-K12D
instead of the shipped with OEM Windows XP Home installed Windows XP Pro (full orig vers) and all Windows and regulary updates recommended by Sony through viao-link already done, means v1.10 dvd update for the above DVR-K12D. The update process was successful without any fault message.
Now, my DVD can't read anything on disks furthermore, no blank CD/DVD, no Sony Recovery Disk - only the orig Windows XP Pro is readable currently.
What and how shall I do to solve the problem?
Thanks.
85 REPLIES 85
profile.country.de_DE.title
seb21__
Stick with ASPI 4.71 from the Adaptec Website!
I would every only download from the original site.
cmsd
I'd download vers471a2 as Kee-Lo said.
The vers471 is on Adaptec Webpages available and the vers472 at CHIP Online in German only which I won't use.
However I tried to re-install the ver471a2 again, re-booted again, but nothing has changed.
Seems to be another part of software as well as not just the aspi driver.
seb21__
Version 4.71a2 isn't the newest version. I use 4.71.
look at the Adaptec site.
cmsd
@seb21
Just in case I'll let you know, that Kee-Lo has right on the vers4.71.a2 as this is the correct one for WXPP.
The vers4.71 is not for WXPP, only WIN98, 2000, Me and NT!!!
Anyway, thank you
seb21__
? LOL, both are for Win XP. But you are right, version 4.71a2 is the newest. LOL[:">] (have look a second time on the adaptec site)
cmsd
No problem at all !
However, I'm still looking for other software faults but I believe I checked all and everything in the meantime twice or more - Can't find anything else apart of this ataptec update.
In regard to the new Ataptec files, how can I control if the files are right installed? They must to find where now? In Windows\system32 or Windows\system32\drivers?
Any special take care of?
Thanks.
kee-lo_
Oh OK, looks like my idea wasn't right.
Maybe then the updates on VL are destroying the dlls in the Windows folder, and thats why it keeps failing.
A full recovery can only prove this, else it's a hardware fault.
Maybe HTS-UK might have a better idea as he's had similar problems.
cmsd
@Kee-Lo
Not at all, I followed to your lines up to here and I'm still looking to your next advice.
It's correct understood, I should recover WXPP with the orig CD???
Doing this, will I loose any data on HDD? I don't think so, as the WINDOWS will be renewed, correct?
Thank you.
kee-lo_
Hmmmm
Do you have Service Pack 2 installed?
James: do you know that command that copies the important DLLs to the Windows directory again?
cmsd
Yep, I use SP2. Anything else I can provide you with in regard to this?
