H E L P !! burning problems
luansille
Hi
I've got a Sony Vaio model VGN-FS115S and have problems burning onto dvds.
The dvds are Philips DVD+RW. I have used Sonic Record Now.
When I make an attempt it spits our the dvd and tells me to put in a new cd. There is nothing wrong with the disc - they are brand new (got 25 of them).
Don't really think it should matter but it is the same whether I want to burn music or a movie.
So, does it matter which dvds I use? Can I not use the dvd but should I use cds instead? Are there a difference besides the amount you can save on them and does it really matter?
What do you suggest I do?
Thanks!
20 REPLIES 20
Vas
Are youtrying to make the recovery discs?
If that's the case for some reason it won't let you use DVD RW
rich912
Contributor
Trying different brands of media is worth a try – Memorex, Verbatim, Sony, also try DVD -RW.
However, with this model, there is always the possibility that your optical drive is a DW-D56A and this may be the root cause. Do a search on this forum “DW-D56A”.
Go n-éirí an bóthar leat
Vas
Hi
I've got a Sony Vaio model VGN-FS115S and have problems should I use cds instead?
Does your model not support DVD+/-RW?
rich912
Contributor
This model supports both + & - RW.
luansille
Apparently it should support DVD+/-RW
Have not made a recovery disc yet........ Had the laptop for 6 months but never really needed to burn anything or had time to play around with it (and do the receovery disc).
Will check if I have a DW-D56A drive.
Can't believe how quickly I got 3 responses! You guys are amazing.
S
luansille
this links to the specifications if that is of any help
http://www.vaio-link.com/specifications/specifications.asp?l=en&m=1810
rich912
Contributor
To identify the model of optical drive, open either My Computer or Explorer, right click on the drive, select properties and click on the hardware tab.
luansille
hmm looks like I have DW-D56A. Is this a troublesome one?
rich912
Contributor
I am afraid so.
As I suggested, do a search for DW-D56A on this forum (or Google) and all will be revealed:smileysad:
