Factory defaults?
bulldog_uk11
Factory defaults?
I bought a PGG-FR415S and wanted to install xp pro.So i run fdisk and formated.I now want to run recovery cd,but i have lost hidden partition.Is there anyway i can reinstall hidden hd?Any info would be much appreiciated as i want to sell to upgrade thanks
6 REPLIES 6
rich912
Contributor
Hi and welcome to the forum.
If you have the recovery CD’s then you can still recover your notebook (look here ), but there is no simple way to reinstate the hidden partition if you have formatted the drive. You could try a format recovery utility but the chances are part of this partition are now overwritten.
Go n-éirí an bóthar leat
bulldog_uk11
thanks for the reply,but ive tried that and no joy the hidden partition must have had files on needed to use recovery cd
bulldog_uk11
there must be something from sony i can use in dos to get factory default?
rich912
Contributor
There are no files on the hidden partition that are required to use the recovery CD’s.
If using the CD’s in Windows you do need some of the Sony Utilities, in particular the Sony Shared Library.The recovery disks, however, should work from DOS, if not then the disks may be corrupted.
bulldog_uk11
ok m8 i will try again,thanks:smileywink:
bulldog_uk11
thanks for ur help guys sorted much appreiciated:smileywink:
