SWF-BR100 compatible Sony tv’s
Pockets24
Hi.
I have two Sony Bravia TV’s, are these both compatible with the Sony SWF-BR100
KD-55X8509C and KD-55AG9.
thank you
4 REPLIES 4
IamNic
Hello @Pockets24,
this subwoofer uses a transmitter, which gets power from USB and uses the audio out (headphones port) as input.
Therefore is is compatible with any TV which has a USB port for power and a headphones out.
- Nic
Pockets24
Hi Nic,
The sub works perfectly with my KD-55X8509C but I tried using the sub on my other Sony KD-55AG9 and it doesn’t want to work.
I’m trying to see if Sony will reply to my message and I can’t seem to contact Sony for any help.
Are you a Sony Expert ?
many thanks
Duncan
IamNic
Hello @Pockets24,
have you set the headphones out port to the mode "subwoofer" in your TVs settings?
As this is a user - user forum, I doubt you will receive any reply from Sony, unless the post is escalated to the support.
That is just how the account-status is called.
- Nic
HannahEd01
Hey pockets24, try the chat service: https://services.sony.co.uk/supportmvc/en/contact?cpint=spt-footer_contact
They answer instantly.
