Bravia XG70 and Humax Box Power
profile.country.AE.title
Steve_Y
New
Hello
When I turn on the TV using the remote, I have then turn on the Humax STB, this isn't a problem. However when I turn the TV off, this also turns off the STB, how can I stop this happening ?   I feed the audio output of the STB into a separate sound system
TIA
Tags (4)
7 REPLIES 7
royabrown2
Hero
@Steve_Y
Try disabling BraviaSync on the TV, see if that works.
However, it make make things like ARC stop working, if you have a soundbar or AV connected, so you may not want to do this.
You don’t say which Humax box it is; maybe you can disable CEC on that. If so, that would be your best option, I think. But I know that on Humax YouView boxes, you can’t disable CEC.
Steve_Y
New
Thanks for the reply
Can't see how to turn off Bravia Sync, I need to find the instruction manual.
It's a basic Humax HDR-1100S Freesat box, can't see any settings for CEC anywhere.
Thanks again
royabrown2
Hero
@Steve_Y
Here’s the bit of the Sony manual that relates to Bravia Sync, Sony’s name for CEC:-
https://helpguide.sony.net/tv/gaep1/v1/en/04-07_03.html?hl=bravia+sync
Humax publish a list of what various manufacturers call CEC, and it must do CEC to behave as you describe, but there is nothing about it in the manual. So I imagine that like YouView boxes, it uses CEC, but you can’t switch it off, nor alter how it works in any way.
Steve_Y
New
Not sure why feedback on  Roy's comment caused him to leave the community BUT it did help me to turn off Bravia Sync which I hadn't been able to find before.
Thanks for both answers
Bat_Rick
New
Could you share with us how did you disable the Bravia Sync?
Steve_Y
New
HOME  /Settings / system settings /Setup / BRAVIA Sync Settings
Good Luck
HannahEd01
Hey Steve_Y
Good Luck
Thank you, that was helpfull.
