Sony BraviaKDL-15G2000 fixing overscan? Is there a service menu?
alessiman
I recently picked up this 15" TV as its the perfect size for old 8 bit computers like the Acorn Electron, Sinclair Spectrum etc.
However the TV has an overscan issue where it wont display the 1st lines of text/graphics
There is an RGB Centering menu setting but that only fixes horizontal centering.  I am after a setting to fix the vertical sizing
Does anyone know if there is a solution for this issue?  TIA
196748844_1667485280116060_1718452396637639706_n.jpeg192197613_1156187921568520_8441373593263479808_n.jpeg
1 REPLY 1
Piscie
Have you tried to disconnect it from the power mains for a few minutes? Could be a power glitch and depowering it sometimes is enough to sort it out.
