kdl 40s2530 getting 9 red flashes
minimejmd
New
hi i have sony bravia kdl 40s2530 and i am getting 9 red flashes after the screen goes black a few times, works fine for about 10 mins after a power reset, tv is out of warranty so anyone got an idea what is wrong with it or parts to exchange, thanks James
4 REPLIES 4
profile.country.GR.title
MiCal1967
Contributor
Hi
You mean 9 LED flashes ?
If you use a MPG4 decoder in CAM slot try removing and inserting again with Power OFF.
If not solved then problem is a faulty CAM reader board or/and Tuner board.
Usually(almost 100%) is a faulty CAM board with a burned out diode.
A Sony electronics technician can repair/replace diode or perform a replacement of both CAM board and Tuner board, which are cheap nowdays, for better and sure results.
Anonymous
Not applicable
Hi there
According to the service manual for your TV. 9 blinks is: DTT Trouble (Communications / BS_CS_PROT)
Advise you to follow MiCal1967 suggestion above.  Just bear in mind that this model TV is almost 10 years old now, parts will be hard to find and probably in all likelyhood uneconomical to repair.
Cheers
MiCal1967
Contributor
philips
New
hi have a sony bravia kdl -40s2530 9 blinks you say it a diode can I ask  which one as I have the circuit diagram .what number is it on the diagram
