KDL-32WD756 - Headphones
Andrewmorris197
Can someone recommend me a good set of headphones compatible with this TV?
Thanks
2 REPLIES 2
LightFoot
Specialist
Hi @Andrewmorris197
As your TV does not appear to have a Bluetooth radio, then literally any wired headphones within your budget would be fine. There shouldn’t be any need to get anything super expensive as I wouldn’t expect the KDL-32WD756 to produce record breaking high fidelity.
royabrown2
Hero
@Andrewmorris197
While I concur with @LightFoot about the lack of native Bluetooth, you aren’t restricted to wired headphones, as you can get setups that work off a base unit you plug in the headphone socket, or you can get a Bluetooth adaptor that will sit on the Optical out, and let you use any Bluetooth headphones you might have, or might buy. Make sure you get a low latency unit though.
My favourite headphones are my Grados, but their open-back design means they leak sound, and so may not be the best option unless you are listening alone. I have a pair of AKG Y45BTs that  I like for Bluetooth listening, still current, though you can now get the more expensive Y50BTs that add noise cancelling, so see which you might prefer.
