Bravia X 80l
SOLVED
WeeMalky476
Bravia X 80l
Is there any alternative to the supplied feet for the Bravia X80L 43 at 28cm and no angular adjustment that I am aware of? These are far too wide for my shelf  at approx 23/25cm with a few cm on either side
2 ACCEPTED SOLUTIONS
Accepted Solutions
LightFoot
Specialist
Hi @WeeMalky476   You could explore using an alternative VESA stand. Sometimes the alternative model numbers X81 or X82 (if available) may meet your needs, the only difference being the stand. There will not be an alternative to the supplied X80L stand.
daveyh64
Contributor
I bought  this or a similar stand for my 43 inch Sony TV,
https://www.amazon.co.uk/1home-Universal-TVs-Height-Adjustable-Management-Holds-32-55-Height/dp/B075...
Make sure you take note of all measurements of the stand so you know you have room for it on your shelf or table top. Check with your TVs specs that the vesa mount screw holes will fit the stand, and the stand can take the weight of your TV.
Make sure you will have enough height clearance for any centre speaker or other devices to sit under the TV.
The above stand is one of many available on that particular website, if. that stand doesn't meet your requirements
then I'm pretty sure you'll find one that does.
2 REPLIES 2
LightFoot
Specialist
daveyh64
Contributor
