usb
Iloveandrew1962
usb
the usb stick is almost full on my sony tv i have recording on i want to keep can i remove  it without loosing them ? and can i use another one do i have to register it on a different hubb number ? thanks
5 REPLIES 5
Bat_Rick
New
Sony TVs are able to record on HDD, which USB stick are you using?
Iloveandrew1962
hi its a sandisk usb in the hdd  rec slot i havent taken it out since i put it in its a 32 gb size
Bat_Rick
New
You can remove the USB stick and you will not be able to use it in any laptop/PC, unless you format it, so if you want to keep it just remove it from the TV and files will be saved.
Iloveandrew1962
if i remove it can i watch the recordings again on the tv ? and can i buy another usb to set up more recordings on it ? im not good at techno
Bat_Rick
New
If you removed it, you will not be able to play the recordings, simply because the files are stored on the USD stick.
