Touch buttons
SOLVED
Combat_333
Touch buttons
Hey everyone,
I have some strange problems with touch buttons. When im press "home" button nothing happends, but phone reply with vibration, so it can recognise the press. Also in some fullscreen apps i'm unable to pull out touch buttons. Who met such problem, or know how to fix it: is this possible without phone settings reset?
1 ACCEPTED SOLUTION
Accepted Solutions
Combat_333
Well, well... In safety mode there was still the same problem. I brainstormed an idea to reset settings, now all is normall. Anyway, thank you very much.
5 REPLIES 5
xavinux
Enthusiast
Hi @Combat_333
Please, from your Home screen first try the following:
1. Tap the Application screen icon.
2. Find and tap Settings -> Apps.
3. Swipe to the All tab.
4. Find and tap on Xperia Home (will reset home screen to default settings widgets/shortcuts).
5. Tap Force stop -> Clear data.
6. Restart the phone.
I´m at disposal for any question.
Combat_333
Nope, no changes unfortunately. It only made mess on my screen Smiling_Face_with_open_mouth_&_closed_Eyes
xavinux
Enthusiast
Hi @Combat_333
Ok, please let´s try boot your device into safe mode as explained here. If this issue is not present in this mode, that indicates a third party app is causing the problem. In this case exit Safe Mode and then un-install any third party apps you don't need and clear the cache/data for the apps you want to keep. I´m at disposal for any question.
Combat_333
xavinux
Enthusiast
Hi @Combat_333
You are welcome, and glad to read that your problem was solved.
