Messaging text after 5.1 update..
SOLVED
ljc20
I noticed some changes to messaging application. After the recent 5.1 update, the messaging text was lighter in print than that of the old one which is not good for reading. I hope they will fixed this.
If you noticed the same issue please make some noise.. 😉
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
ljc20
You are right. There was an earlier thread with regards to this issue. I found the answer under the thread of transparent messaging. Turning the delivery report off will solve the issue. 😉 i wonder how can i delete this thread?
6 REPLIES 6
Uliwooly
@ljc20
It has been posted a while back, you might want to use Google messenger.
ljc20
Messaging is different from messenger in many aspects.
Thanks for the reply. 😉
Uliwooly
@ljc20
Anytime
ljc20
I found the solution.
Thanks.
Uliwooly
what's the solution?
ljc20
