magnetic cable
SOLVED
Mrcrown
magnetic cable
I use for my z3 compact a magnetic charging cable, Does the z5 compact support the same option?
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.US.title
Qatrium
Magnetic charging ports have been removed from the whole Z5 family, but you have an exposed USB port at the bottom.
3 REPLIES 3
Qatrium
Hampus
Champion
Just like Quester said, the magnetic charing dock connector has been removed on the Z5-series. But there are also a charging dock for the Z5-series, check the following link:
http://www.sonymobile.com/global-en/products/accessories/micro-usb-charging-dock-dk52/
Mrcrown
Thnx for the quick response, its a real bummer...
