Can use Xperia Companion
atar14
New
So I was given a phone by someone and when I tried to get it reset by Xperia Companion it says this:
UEGetPhoneInfoRootedDeviceUE_20032.11.6.0
Windows 10 64 bit
Win32 / US
Its an Xperia E5823.
Any clue what I can do to fix this?
5 REPLIES 5
Strampke
Try this:
- Delete the Google account or remember your credentials to enter
- Charge device to > 80% and switch it off
- Open Xperia Companion and do Software repair
- Tick the "my device cannot be detected or started, or is a SmartWatch 3"
- Follow the instructions
If that doesn't work than go read about Xperifirm.
atar14
New
Cheers, I tried that and it didn't work. Same thing. I will look into that, thank you!
Oh and I wrote this on my phone, autocorrect is responsible for the title...
atar14
New
So I managed to download the correct firmware through the app you
suggested. Now I am trying to use something called Flashtool to try and
flash that to my phone.
https://androidmtk.com/download-sony-mobile-flasher
It gives the following error message when I start it up. I have tried
giving zip.dll file admin rights but nothing. I have no clue how to switch
it to English so I found a way to translate what it says:
FlashTool64.exe - Insert point not found
The JVM_GetLastErrorString input point of the process
could not be found in the dynamics library
C: \ Program Files \ AdoptOpenDK \ jre-8.0.282.8-hotspot \ bin \ zip.dll.
Any idea if there is some other program I can use to install this?
Strampke
For that specific area you'll have to go to XDA Developers.
EMS_MO72
You can try to test another PC or laptop with the Xperia companion also and check again, make sure that you download the latest update from the Xperia companion,you can check this link: https://www.sony.co.uk/electronics/support/mobile-phones-tablets-mobile-phones/articles/00236877
