USB PORT COVER
SOLVED
brobbins-317
USB PORT COVER
does anyone have problems closing the usb port cover.  i can't get mine to close.:smileysad:
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi brobbins-317,
As far as I am aware there has only been one other report of this problem on the forum.
https://www.sony-europe.com/discussions/message/726851#726851
Unfortunately creynish didn’t report back on the outcome but if you post in that thread you may possibly get a response. Otherwise use the link provided to contact support.
Rich
Go n-éirí an bóthar leat
4 REPLIES 4
longtreeroad
They are a bit tricky to close, have looked to make sure nothing is in th way
rich912
Contributor
Hi brobbins-317,
Rich
Chayton69
i had the same problem shortly after I got my tablet. i thought it was going to be a return to the store  job but i managed to fix it. The problem is that it is a generally crap design. The plastic "hinge" bunches up on itself and prevents the catches from locking properly.  I fixed mine by using a papderclip to hold the hinge flat while i closed it. Not the best solution but it worked. That said, i have not opened the cover since!
creynish
Guys thought I updated but obviously not.
returned mine as it would not stay closed replaced with no questions asked and all fine now
