How do I connect to an exchange server?
SOLVED
paul-87
Having a problem connecting to a (work) exchange server, anyone with any tips? Gmail was a breeze, but the exchange is prooving a challenge..!
thanks, Paul
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.nl_NL.title
breedBenR
do you have instruction sheet from your it people adminning your exchange server?
y ou may need some hard to guess parts such a a domain part before your username,
and the correct name of the server you connect to. Just your emailadress, pwd and login are not enough..
2 REPLIES 2
Watashiwateshdes
Contributor
Hi Paul
Where did you get stuck?
breedBenR
