I always listen in NC mode but for every use after about the first 10 minutes it randomly switches to Ambient noise mode. And no I'm not pressing the NC/AMBIENT button! Is this a common issue? I'm running firmware 2.0
Solved! Go to Solution.
@Panifex schrieb:
Do you have Adaptive Sound Control turned on?
This was happening to me, and that was the reason.
I too assume that this is the issue here.
You can deactivate it in the options of the "Headphones Connect"-app.
- Nic
Hi Brian,
Welcome to the community.
I'm not too sure but I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might be able to shed some light on this.
Thanks,
Pascale
Hi Brian,
Welcome to our community!
Have you tried to initialise it to factory settings? You'll find instructions on how to do that here.
Let us know if this resolved the issue.
Cheers,
Batee5
- Nic
Sorry for the delay. Yep this was it!
Thanks
You're very welcome!
Okay so why have a feature that completely affects the experience of these headphones.
I was running and every 30 seconds it does this and the only fix is to turn the super nice (would be nice to have) feature off?
Surely there’s a nicer answer.
Hello @HaydnNeese,
the answer might surprise you - because some people actually use/want said feature.
A computer might be able to edit videos or program a game, this still doesn't mean you can't use it to just browse the internet on.
- Nic
