WF-1000X Right earbud flashes when in case then does nothing when taken out.
Doesn't connect to the other earbud or phone.
Can anyone help with this issue please?
Hi @AndrewOwie and welcome to the Community
Have you tried a reset to factory settings to see if that helps?
If this doesn't help, I would contact Support on +44 (0) 2073652810
Did you ever get to a resolution to this problem? Seems both a charging & pairing problem.
