Command using wh-1000xm3 headphones
SOLVED
profile.country.SE.title
kstrid5365
New
I think I can tap on the right ear phone in order to start/stop music answer mobile etc.
Where do I find a description over these commands.
1 ACCEPTED SOLUTION
Accepted Solutions
ProNoob
Check this link to learn more about the location and function of parts here: https://helpguide.sony.net/mdr/wh1000xm3/v1/en/contents/TP0001703149.html?search=buttons
You can connect the headset to the Sony | Sound Connect app to customize the audio settings to work with your headphones check the link to learn more about how to connect the headphone to the app: https://helpguide.sony.net/mdr/wh1000xm3/v1/en/contents/TP0001867143.html?search=app
1 REPLY 1
ProNoob
