Last night, I visied VAIO Update for the first time in a long time, and downloaded and installed, amongst others, the Wireless LAN Stater Update version 4.1.100.1332.
From that moment on, at every boot and restart, I get an error message telling me that there is a problem with the Wireless Switch Setting Utility and that it will be closed - I then have the option to send an error report.
This is, I admit, my own stupid fault for trying to fix something that was working well but I would appreciate any ideas to solve the problem.
Laptop is a VGN-S4M
Hi Charley_Lima,
Have you tried a System restore to a point before you updated your wireless LAN Starter..
Good suggestion but a while ago I reduced the size of the restore point cache when I was editing some videos and forgot [as one does] to increase it - there is therefore no appropriate restore point.
Are you aware of other problems with this particular upgrade?
I have the same problem I have updated the wireless driver and get an error message when i restart, i have tried a clean install it still does it, i have just contacted e-support which i am waiting for a reply i will let you know what they say
Hi Charley_Lima
You can download the pre-installed utilites from Vaio-Link , this should contain the original Wireless LAN Stater..?
As Sony Support's best effort was to reinstall from scratch, I decided to try uninstalling the Wireless LAN Starter and associated software. This seems to have worked as there is no error message and my Wirless LAN is working perfectly. Obviously a Sony innovation that XP is able to replace. It has to be said that Sony computers work far better by avoiding Sony software.
My similar problem: At every boot and restart, I get an error message telling me that there is a problem with "Switcher.exe" and that it will be closed, with option to send an error report. (So I have deactivated switcher.exe in msconfig.exe, it is not really important.)
Another problem: I get a corresponding message after starting "VAIO control center.exe", this is not really funny.
(Model VGN-S4M)
(Model VGN-S4M)
