I have recently bought a RZ504 and am trying to set up the wireless LAN and the Media bundle. Everything is plugged in correctly and the software is installed. In the windows tray there is a black icon with an exclamation mark saying that the wireless panel PCWA-C300s is out of range. I do not know where to find the network name ( SSID) or the network key. Can someone please help me with this!!!???:smileycry:
Hi there there should be a setup document that came with the computer that talks you through setting up all the differnet settings, also there is a document CD that helps get the settings right. If you dont have this document i can get you a copy of this.
When you are trying to set it up make sure that you do this near the computer first. Once you have it set up start to move it away from the computer to get an idea of the range.
