Hello,
After a clean Vista installation on my VAIO VGN-FE21S I've just added the video and the audio driver. Now I want to add only carefully selected Vista drivers, utilities etc. which can be downloaded at
http://support.vaio.sony.co.uk/downloads/select/select.asp?site=voe_en_GB_cons&category=0&serie=VGN-...
BUT there are no explanations which download is for which pupose. OK for some downloads the name says what it's for, but for what purpose are these:
- Other:
??? For which purposes is this, please?
- SonicStage:
??? Is this full Vista version, or how do I install it on a clean Vista installation?
- Sony Shared Library:
- Sony Utilities:
??? For which purposes is this?
- Sony Video Shared Library:
- VAIO Control Center:
??? Has this advantages better than the Vista Control Panel?
- VAIO Edit Components:
- VAIO Event Service:
- VAIO Power Management:
Has this advantages better than the Vista Power Management?
- Wireless Switch Utility:
??? Do I have to install it, if I don't use wireless devices at all?
- Bluetooth:
- Input Devices:
??? For which purposes is this? Just for the touch pad?
- Modem:
??? Do I have to install it, if I just want to use Vista Ultimate Fax?
- Multi Card Reader/Writer
??? For which cards is this, please?
Thanks in advance for your answers!
With Regards
Why dont't you install all the downloaded drivers and applications which you listed? Then if you don't like some, uninstall them!
After me, all these are needed for the "well working" of your Windows Vista.
Why don't you install all the downloaded drivers and applications which you listed? Then if you don't like some, uninstall them!
