hi just like 2 mins ago i just got this little yellow exlcamation warning sign saying ....''virtual memory minimal'' ...umm i was wondering how do i fix this
thanks
bianca
xx
Hi bianca,
Are you trying to run a game or do you have a lot of programs open? Is your C: drive nearly full?
This usually means that you could do with installing a bit more RAM memory.
As a workaround, you could increase the Paging File (Virtual Memory) size on your hard disc.
1. Click Start, and then click Control Panel.
2. Click Performance and Maintenance, and then click System.
3. On the Advanced tab, under Performance, click Settings.
4. On the Advanced tab, under Virtual memory, click Change.
5. Under Drive [Volume Label], click the drive that contains the paging file that you want to change. This will almost certainly be C:
6. Under Paging file size for selected drive, click to select the System managed size check box, and then click Set.
7. Click OK three times.
When you are prompted to restart the computer, click Yes.
You could also try uninstalling dead stuff,free up disk space,then do a defrag of your HD.
thanks frannys and blencogo for your help it is much appreciated ....blencogo i will definatley do the thing you said 2nyt when i get back home
thanks alot guys
xxxx
That's, as frannys says, means you have low hard disk space
