Hi all
will be upgrading tomorrow top vista ultimate. run the vista checker on the machine and said I was fine to use business version and if i wanted ultimate.
the downloadable check stated that i wont be able to use finger print recognition after upgrade until i have the driver. is this available yet ?
has anyone else upgraded their TX3XP for Vista ? What have you experienced ? I'm not expecting it to go totally smoothly...
cheers
steve (UK)
You can download the TX3 XP pre-installed drivers and utilities from here
Hi Steve
Sony Notebook Control
Sony Programmable I/O
You should find these in Pre-installed Drivers file, they may also be as philfree said in your CD that you created..
Thank you. I'm looking for the SonyNC and SonyPI Drivers on the website. Are they in the TX3 Utilities.Zip File on the download link ?
Thanks guys, all downloaded and installed. Now all working a treat !
I have 1 issue that I cant seem to work out.
Still no internet.
1. In my right-hand task bar it show 2 computers when my mouse goes over it, it says "Currently connected to network:local and internet".
2. When I ping, sat www.bbc.co.uk it says " ping request could not find request. could not find host.
3. Open internet explorer - tries to open home pae but nothing.
4. In nework & sharing center it shows full green line between Laptop-Network-Internet.
5. I click on new network setting, set up to connect to internet say " you are already connected".
6. Select connect anyway. Only one option connect broadband PPOE.
7 Connection fails.
8. Open up outlook to chack mail. says not connected.
In Ip settings I have "get automatically" as instructed by isp.
No firwalls, even turned of windows firewall. Still no luck.
In network setings I have never dial a connection.
Router works fine with XP on other PC.
Any thoughts ?
Steve
Also, a completely different possibility that was the problem for me at first was that my firewall/router appliance was incompatible with Vista and needed a firmware upgrade. (I have a Linksys RV082.) It seems that there are a number of routers out there that need upgrading to support the Vista TCP stack.
(I did have some Internet connectivity, however, but with lots of failures to load web pages.)
Staffan
