vga output on my sony fz11s is poor, to be more precise: blurry
I use a good quality cable and connect it to a crt trinitron sony with 1600x1200 resolution. Lower resolutions are blurry as well. Playing with the refresh rate helps getting the picture more sharp, but gives me an annoying flicker.
I assume the videocard is powerful enough to drive this monitor? An older laptop with older videocard once gave me a good quality picture...
After searching the net for quite some time now, there seems to be no solution for this problem yet...
Very grateful if someone (at least a sony employee) could give me an answer, since this problem is 'big'!
Hope to hear from you soon!
Cheers,
Rolf (Amsterdam)
