hi, I have a problem.
Mu notebook is very noisy... just when my notebook is 2 min on power he is just an airplane... a friend of mine has just the same notebook and is not so noisy as mine.. his is less noisy.. it's quite... So I'm a little affraid now what i'm suppose to do...
I Live in THe Netherlands... does someone has an idea?
follow the instruction on this page:
http://mitglied.lycos.de/innovations/
sorry it's in german only but there are some picture.
Also in my site www.gruppo-sfera.com on the wiki page "operazione vaio", there is a description but only in italian. there is also an image where you can see the dirty I put out from the fun...just with hand because the air compressor is not enaugh.
ciao
gabriella
I did'n force nothing. I don't know. HAve you a picture?
you have to push the cover from right to left and then the cover is out. try.
the noise is away and the warmth, well it's reasonable.the noise is away and the warmth, well it's reasonable.
Hoorah - I can now think and work on my laptop. The noise on performance was deafening.
Thanks a lot.
But what is the difference between performance and quiet - apart from the obvious
Performance means you use full CPU power.
You should have had the desktop I had 3 years ago, had a Volcano 7 -- VERY LOUD indeed.....
would you have similar advice on reducing tempreature for a k215b notebook?:smileysad:
The same technique should work...
