VAIO EVENT SERVICE MANAGER (VESMgr.exe) HIGH MEMORY AND CPU LOAD
sny888
Hi all!
I have a weird problem with the VAIO Event Service Manager (VESMgr.exe). When I boot up my FE41S the process starts normally, but the CPU load is about 20-30% and the RAM usage continuously increases (after about half an hour memory usage is about 400MB) and terminate itself when there is no excess memory left. Buttons still work, but there is no visual feedback. This problem also causes the fan to spin up more often. If I terminate VESMgr.exe in the taskmanager, everything is back normal, but the buttons don't work anymore. :slight_frown:
Does anyone has a solution to this problem? Is there someone out there that has the same problem?
0 REPLIES 0
