Besides weight, dimension, disk size and price, is there any other differences between 20GB and 40GB ?!
Does both have the same battery playback time ?
Yes they both have 20Hours Battery hours.
Vas
And do you know if the hard-disks have the same caractheristics (rpm, seek time, data buffer) ?
uhm rpm, buffer and so on should be the same, the only different thing is the capacity i think
The 40 Gig is a little bit faster than the 20 because it has more heads (2 more).
The 40gb unit does not fit PDAIR's very nice leather case!
i think the battery in the 40gb is a bit stronger so that the battery life is left the same...
Yes, u are right! (it is stronger)
So in your opinion if one does not need the extra space of the 40GB, there is no other (technical) reason to exchange my 20GB for the 40GB, right ?
Thanks for any help.
