USM16GLX 16GB MicroVault Click Excellence - capacity issue
SOLVED
supersub70
Hi - I've been given a Sony USB stick which is marked and sold as a 16GB drive however when formatted it only shows as 4GB avilable. I have formatted the drive in both FAT32 and NTFS and both return the same total capacity (4GB) - Is it possible a 16GB chasis has been mixed up with a 4GB stick at the factory? Or is there something else I'm missing here?
Regards
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi littlejon87,
The 4GB transfer limit would suggest that the Flash Drive is formatted as Fat32 – 4GB being the maximum file size that can be stored on a FAT32 volume. Fomating the drive as NTFS should solve the problem.
Rich
Go n-éirí an bóthar leat
5 REPLIES 5
supersub70
Cancel that! My USB had been partitioned for use with a Juniper Device (somehow).
for info I ran a cmd.exe then as follows;
1. Diskpart
2. Select disk 1 (assuming the USB is assigned disk 1 - check in Windows Disk management first!!!)
3 .Clean
4. Create Partition Primary
5. Select Partition 1
6. Active
7. format fs=fat32
8. assign
9. exit
NOTE: I actaully only followed to point 3 then went to the Windows Disk Management console to do the rest.
Happy Days
:slight_smile:
littlejon87
I'm having a similar problem, although my 16gb shows it has the 16gb free.
when I try to transfer a file of 8.5gb it says the file is too large, same with 4.5gb. Anything below 4gb does fit however.
So is there a file size transfer limit?  Or is the software that comes with it meant to 'simulate' a larger drive, and it's actually only a 4gb drive?
thanks
rich912
Contributor
Hi littlejon87,
Rich
littlejon87
Thanks for the info!  Re-formatted it and works a charm - thanks
When I reformatted it, it asked for allocation unit size?  Do I need to bother changing any of this? I left it at 4kb
rich912
Contributor
Hi littlejon8,
Please to hear that this solved your problem :slight_smile:
4kb is the default and max cluster size for the drive capacity you are using. If it is working leave well alone.
Rich.
