i have a usb2 card reader that will not install into windows XP, the only message i get is that the device has malfunctioned and windows cannot recognise it, thinking it was broken i bought a new card reader but that is just the same, the device manager says that the drivers are not installed, but i have installed the driver disk that came with the reader. All my windows updates are fully up to date. can anyone help me!!!!
i had the same problem with a different bit of kit.
have you uninstalled and re-installed it?
Do you have it on and working during boot up?
its plugged in while the pc boots up yes, but the hub light goes out after a second then the pc reboots as normal, as though it ignores the card reader. when i unplug and plug it in again i get the malfunction message again, and i have reinstalled the supplied software loads of time, all with no success
I would go to the manufacturer for support, it could be a lot of things. If the supplied software isn't working. it may be an obscure bug in which case it's unlikely you will get a solution here.
