Hi friends,
I have sony note book- PCG FR 315S. i would like to upgrade the memory of it. When I looked on the sony style, they have only up to 512mb module. Is that the maximum memory i can install on my notebook? Do i need to install only the vaio module?Will it make any problem to my notebook if i use any other modules cheaper than vaio? If not , does anybody know where i can buy a cheap memory module up to 2 gb?
Many thanks
kishore james
Hi kishore,
Your Vaio has two memory slots and you can install up to a maximum of 1024mb by installing two 512mb modules.
You will need to check if you have one 512mb module or if you have two 256mb modules at present. If you have one you only need to buy one extra but if you have two small 256mb modules, you will need to buy two 512mb.
Go to this link CRUCIAL where you can buy your extra modules. On the left of the screen, click on Crucial System Scanner - this will tell you what you have at the moment.
Hai,
Thank you very much. At work at the moment, I will do the scan as soon as I reach home.
Many thanks
