HI ALL. I OWN A FE11S AND IT WORKS QUITE WELL. HOWEVER, FOR THE PAST FEW MONTHS THE SCREEN HAS STARTED BLINKING (TURN OFF AND ON). IT HAPPENS QUITE OFTEN AND I THINK THAT IT IS MORE INTENSE WHEN THE PC IS PROCCESSING. TO FULLY INFORM YOU, A TECHNICIAN ONCE CLEANED MY SCREEN WITH A LIQUID USED FOR WINDOWS (LIKE AZAX). DO YOU THINK IT IS RELATED TO MY PROBLEM?
THANKS IN ADVANCE..
sounds like the liquid has caused a short by getting past the screen cover. i only use an anti-static foam to clean my screen, which is safe if it gets behind the case.
