This happens a lot, especially when I am playing a video of any kind. Dosen't matter what player I use, it will play fine for a few minutes somtimes up to an hour or more, but then suddenly the sound goes funny for few seconds and the system reboots on its own! I have sent this into repair 4 times now but all they seem to do is run diagnostics dont find anything wrong and send it back :smileysad:.
Anyone else has similar problems?
It sounds like an overheating problem that will only show itself under a heavy load.
Try downloading a utility program which monitors CPU and GPU temperatures and see if either are overheating. Something like PC Wizard 2010 should do the trick.
http://download.cnet.com/PC-Wizard-2010/3000-2094_4-10793737.html
Have you checked that the air vents are unobstructed and you are not using the Vaio on a soft surface like a bed - this will block the vents.
Do you get a Blue Screen just before it reboots?
