Hello,
I am the owner of the VAIO VGN-SZ2M with 2 x 40GB HDD´s.
Now one of the HDD is full of memory and I dont know how to activate of use
the other HDD realtime...
Thank you for your help.
Shigekixx
Hi
Your SZ2 has only one hard drive which has been split into two partitions, C & D drive.
If you C drive my documents folder is large and has been filled with photo's, or documents etc you could start by moving them to your D drive. To do this simply Change the Default Location of the My Documents Folder, see here
The advantage of moving your My Documents folder to d: is that if you need to reinstall windows then you already have most of you documents on the second drive.
That's good advice Kai-Zen..
Hi Kai-Zen
So if I have only one HD, then how come it is splitted??
Is there any way I could "combine" the C and D drive it into one HD?
So that I have only C Drive...
Hi Shigekixx
There are benefits to be gained in having a partitioned drive..
For example if you store your personal data, pictures, etc. on the D drive and a problem occurs with the operating system, the C drive can just be recovered, by following this guide, therefore hopefully, leaving your personal files on the D drive intact..
However if your sure you do not require a partitioned drive you can resize or remove the D partition buy either using a third party program such as Paragon's Partition Manager or by using Sony's Recovery Utility selecting C: & 😧 Drive Recovery (change Partition sizes when you reach point 10, note then if you use the Sony Utility all the files and programs on the C & D drive will be deleted before the original operating system and programs are restored..
It would be a good idea to create a couple recovery disc sets before you make any changes..
