I would like to add a sec graphic card to enable me to use dual monitor.
The current one is agp so the next would be pci.
What should i buy? I have seen some for £40 about my price but will pay more.
I do not use 3d but do work on large pictures (600mb+)
The second mon will mainly be used for static pics and a screen full of printing.
Thanks for any help.
I now find i can not use a simple converter as the outlet is digital and the monitor is analogue.A converter costs $400 i am told.
Back to the drawing board.
Back to the dual outputVGA cards then.
I now find i can not use a simple converter as the outlet is digital and the monitor is analogue.A converter costs $400 i am told.most cards with a digital ouput come with a convertor (simple cheap thing) but that one is different that the one you are mentioning. If the card supports both its cheap, if not... then you need the expensive convertor (Or buy a kickass TFT)
Unless you buy a DVI monitor, like Oxi suggested, then you will need to go for something like the Matrox, again suggested earlier as they have 2 VGA heads on them.
