Basically i asked someone on here a while ago how i can get a windows xp pro disc because it wasnt supplied with the laptop and he said there was a recovery disc wizard which i found. I ordered some DVD 4.7GB RW discs brand new and when i try to do the wizard it says please insert a "blank" disc which it is.....I tried it with other discs i ordered and exactly the same hting happened.
So is there a way to make this work?
OR
I want to upgrade to Vista but just in case i want to know if i would be able to get back to XP and without a disc is there a way???
Hi tman16,
You can not use DVD RW or CD RW disc's to create your recovery disc set..
