Hi, When burning a PE video project the system sometimes fails with an alert "Unknown error 2130970881" or some such number. My preferred DVD media is DVD-R and this generally works but not always. In order to overcome such problems the Premier Elements Forum recomends burning the project to a folder and then burning the folder to a disk. Thus I burned to a folder which results in two main sub folders Video_TS IFO File and VTS_01_0 IFI file and some others. The Help feature in my Vaio instructs to use the DVD burner software preinstalled to copy (drag?) the folder. However, the only softward I can find is the 'click to DVD Ver 2.5 and this does not seem to have any facility to import video files for burning directly to a DVD. I would appreciate assistance and guidance. Thanks. Kesa-
Hi Everybody! 40 views of my message and no suggestions. Help! :smileygrin:
Hi Kesa,
If you download Deepburner then you'll be able to burn the folder to a DVD in the correct mode.
Can a CVE please remove the last post here? (no not mine LOL)
