PCV-RS 504 - Memory Upgrade
SOLVED
profile.country.it_IT.title
frpitac
New
I have a PCV-RS 504 with 1GB RAM, and want to take it to 2GB.
Actual Slots 1 and 3 house 1x512 each; 2 and 4 are empty.
I bought 2 x 512MB DDR400 and placed them in empty slots. Power up is ok, and BIOS shows 2GB RAM,
BUT after I work for a few minutes the PC freezes. Nothing moves, only way out is hard power off.
Can anybody give me some help?
Thanks, franco.
Tags (3)
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi Franco,
Try reseating all RAM – just in case there is poor connection.
Also, are the four modules identical in specification? This normally is not a problem but may possibly be the cause, or you could have one faulty module or slot.
Assuming that the supplier of the memory has a no quibble returns policy you may wish to consider purchasing two 1GB modules  and place them in slots 1 & 3 – they are quite inexpensive...
http://www.crucial.com/uk/store/listparts.aspx?model=VAIO%20PCV-RS500%20Series%20%284%20DIMM%20socke...
Rich
Go n-éirí an bóthar leat
1 REPLY 1
rich912
Contributor
Hi Franco,
Rich
