hi guys,
I bought sony vaio pcg-k315m yesterday.
Everything is fine but the laptop gets heat so fast and the fan nose is too too much ..
is there any problem... or what can i do ..
please help me in this regard..
mfg,
kings
Imagine if I had a quid for every post...................?
hi guys ...
still i am not sure ..
I have some questions ...
1.did the fan runs continious for you...
2. what about the noise level .. I dont have anything to compare with
do u think this is the problem of this model or mine
thanx in advance..
mfg,
kingsly
Kingslee - The problem is the processor which can run at 3.06GHz when it needs to. Now really give this processor a real stack load of work- say 90 -100% of max, this thing is really flying then and so it generates heat. It also has a higher voltage than say a Pentium M, and so work + voltage = heat.
So to the second part of the problem ( which I think Seb mentions above). This processor was designed for a desktop where there is enough space to glue a whacking great heat sink and integral fan to the top of it. In a laptop there just isn't the room and so they make a plan to stop it melting, and that is to put a high air flow fan in to keep control of the heat produced.
I think it is a processor plus model/design problem, but I prefer to have a laptop which can really work when I need it to. My 1.6GHz desktop drives me crazy while it thinks....I call it daft bast***!!!
Thank you for the reply & the info GBS...
That speed switching is working good.. and
If the case is normal i hav to stuck with that
with no load also the fan runs ...
but i see some quite laptops from other companies... fan runs when its overloaded..
i can return this... i hav one week time...
whats ur suggestion ... guys.
anyway thanks for u guys ,for considering my query...
mfg,
kingsly
They should let me borrow VAIOs so I can help with specific problems
Lol well they should give me one of each model for testing too! i don;t see why i should be left out!:smileylaugh:
mfg,
kingsly
Thanks guys...
Is there any temperature monitoring software for windows xp ...
I am also searching for that..
If i find something i will post it here ..
if any body know .. pls,..
cheers
kings
i got one from pur forum ,,
i should had searched the things first ..
http://www.club-vaio.com/clubvaio/mvnforum/viewthread?thread=26963&pager.offset=0
cheers
kings
