Im desperate for some help -
All of a sudden my SD card has stopped working and so have all the shortcut buttons around my keyboard. The AV mode wont work either.
I cant seem to find the drivers/files for these things??? Theyve disappeared.
Ive looked in the download section to try and reinstall them, but i cant find the right drivers.
Im using Vista.
Any help would really be appreciated.
Thanks in advance
Can you give us the exact model type - it will start VGN- and you will find it on the screen surround?
Ah, just found it. Its VGN - AR31M.
Id really appreciate your help Blencogo.
Hopefully it is just the drivers and utilities that have stopped functioning but it seems odd that all these things should happen at once and I wonder if something else has caused these problems..
You can download the Original Drivers Package and the Original Utilities Package from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-AR31M
Both these .zip files will need extracting by right-clicking on the .zip and chooseng 'Extract All'. Extract the files to a folder where you can find them. (C:\ is as good as any).
For the SD Card, you need to reinstall the Memory Card Driver from the Drivers Package. For the Fn Keys you need to install the following - in order - from the Utilities Package: -
Have a look in Device Manager and see if any of the hardware devices have a yellow ! warning next to them. This will tell you if other drivers need to be reinstalled.
Thanks Blencogo!
Seems to have done the trick! I really appreciate your help.
Could you help me out with one more thing.
My internet connection is terrible - its intermittent - sometimes good, sometimes limited connection.
I have another laptop, and the internet connection is perfect.
Any suggestions on how to sort that out??
