My laptop recently needed to be re installed.
On boot up the display is about two inches bigger than the screen.
I have to re install the dispaly driver, re boot and all is fine untill the next time.
I have a FX 804 with on board ATI graphics chip.
My device manager has it as a Mobilty M1. Driver version 6.13.10.5796 Dated 16/06/2002.
Under details it has...
ASIC Type : RAGE Mobility
ASIC ID : 4c4d
Bus Type : AGP 1X, AGP 2X
BIOS Version : 4.228
BIOS Date : 2002/05/31
Memory Size : 8 M
Memory Type : SDRAM
Driver File : Ati2drab.dll
Release Version : M6.12-020616m1-004662C-Sony
Memory Upgrade Modules : Not Appicable
Multimedia : Video Stanard NTSC
THANKS
RICK
Hi Rick,
If by this you mean that in order to view the peripherals of the screen it is necessary to move the mouse to the left or right border then the resolution is set incorrectly.
Right click any blank area of the desktop and select properties > on the Settings tab move the slider bar (screen resolution) to the left by one increment and then click apply. If this does not correct the problem then repeat the procedure and reduce the resolution by a further increment.
I think that the recommended resolution for your model should be 1024x768
Btw Rick, pleased don't cross post as this only wastes our time and also leads to confusion.
