ocz memory question
chrissy.y2k
ocz memory question
OCZ 512MB PC3200 Platinum Edition:-
any ideas if this memory will wrk with rs 402???
:clown: "Sex is no laughing matter - unless you're having sex with a clown!!" :clown:
5 REPLIES 5
reaper
your pc came with pc2700 ddr sdram didnt it ?
i imagine everything will be o.k
chrissy.y2k
no it came with 3200 ddr 400 memory.... so u reakon it be ok??
"Sex is no laughing matter - unless you're having sex with a clown!!" :wink:
kee-lo_
Nice.
reaper
if it is the same spec it will defo be fine
where are you buying it from the internet shops normally have memory search engine's which tell you weather it is compatible enough
i use this place its a little expensive but its a good company next day delivery always !!!
i have never had different unless it is ordered on the weekend
regards ben
chrissy.y2k
cheers reaper i'll have a look at that link... the only site that i have come across that shows compatible memory is
www.Crucial.com checked out sony rs402 and came bk with DDR333 PC2700: - :neutral:
little miss leading!!!
:angry: :angry:
